UG二次开发问题:我在建模环境下用UF_UI_select_with_single_dialog()没问题,在组件工程图模式下用UF_UI_select_with_single_dialog()却选 不中零件,是什么原因??
tag_t object,view;
char cue[] = "select object ";
int scope = UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY;//UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY,UF_UI_SEL_SCOPE_WORK_PART
char part_fspec [ MAX_FSPEC_SIZE+1 ];
int response;
double cursor[3];
tag_t part_tag;
CString infro;
UF_UI_select_with_single_dialog(cue,"select the object",scope, UF_UI_sel_part, NULL, &response, &object, cursor, &view );
if (response == UF_UI_OBJECT_SELECTED ||
response == UF_UI_OBJECT_SELECTED_BY_NAME)
UF_DISP_set_highlight(object,0);
UF_MODL_update();
static int UF_UI_sel_part(UF_UI_selection_p_t select, void * user_data)
UF_UI_mask_t mask_triples[] = {UF_component_type, 0, 0};//UF_component_type(组件中选择零件)
if (UF_CALL(UF_UI_set_sel_mask(select,UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,1,mask_triples))==0)
return (UF_UI_SEL_SUCCESS);
else
return (UF_UI_SEL_FAILURE);
