楼主 |
发表于 2013-8-20 09:46:35
显示全部楼层
可是,我在原来的公司的时候,公司有编一个宏程式,执行那个宏,就可以了!我贴下原码,你给看下!这个宏是在7.0版本下用的,10.用不了!你给改改!
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
EDIT MODEL ALL DESELECT ALL
ACTIVATE WORKPLANE "1"
UNDRAW NCProgram 'R0001'
UNDRAW NCProgram 'R0002'
UNDRAW NCProgram 'R0003'
UNDRAW NCProgram 'R0004'
UNDRAW NCProgram 'R0005'
UNDRAW NCProgram 'R0006'
UNDRAW NCProgram 'R0007'
UNDRAW NCProgram 'R0008'
UNDRAW NCProgram 'R0009'
UNDRAW NCProgram 'R0010'
UNDRAW NCProgram 'R0011'
UNDRAW NCProgram 'R0012'
UNDRAW NCProgram 'R0013'
UNDRAW NCProgram 'R0014'
UNDRAW NCProgram 'R0015'
EDIT NCPROGRAM PREFERENCES EXTENSION "_LaserV22V33-Cu" "V33"
DEACTIVATE NCPROGRAM
DEACTIVATE TOOLPATH
DEACTIVATE TOOL
DEACTIVATE BOUNDARY
DEACTIVATE PATTERN
DEACTIVATE STOCKMODEL
DEACTIVATE GROUP
UNDRAW TOOLPATH ALL
DELETE SCALE VIEWMILL RESIZEVIEW
FORM BLOCK
DATUM ACCEPT
EDIT NCPROGRAM PREFERENCES TAPEOPTIONS FILEOPEN
"C:\dcam\pmill2\POST\_LaserV22V33-Cu.opt"
EDIT NCPROGRAM PREFERENCES TOOLCHANGE NEW
EDIT NCPROGRAM PREFERENCES LOADTOOL ON
EDIT NCPROGRAM PREFERENCES COOLANT NONE
NCPREFERENCES ACCEPT
edit fstrip 0.02
VIEW MODEL ; WIREFRAME ON
VIEW MODEL ; WIREFRAME OFF
ROTATE TRANSFORM ISO2 VIEWMILL RESIZEVIEW
EDIT BLOCK TOLERANCE 0.005
EDIT BLOCK RESETLIMIT 0
EDIT BLOCK LIMITTYPE MODEL
DRAW BLOCK
EDIT BLOCK DRAWMODE 0
UNDRAW BLOCK
EDIT BLOCKTYPE BOX
BLOCK ACCEPT
FORM FEEDRATE
EDIT RSPEED "36000.0"
EDIT PRATE "500"
EDIT FRATE "1000"
EDIT RPM "10000"
EDIT CYCLE_FEED "0"
EDIT COOLANT NONE
FEEDRATE ACCEPT
FORM TOOLZHEIGHTS
EDIT TOOLPATH SAFEAREA DIRECTION I "0"
EDIT TOOLPATH SAFEAREA DIRECTION J "0"
EDIT TOOLPATH SAFEAREA DIRECTION K "0"
EDIT RMOVES SKIM
EDIT ISAFZ "3"
EDIT ISTAZ "1"
EDIT ISAFZ "3.0"
EDIT TOOLPATH SAFEAREA RESET
TOOLZHEIGHTS ACCEPT
FORM DATUM
EDIT DATUM PAGE END
DATUM ACCEPT
FORM LEADLINK
EDIT TOOLPATH LEADS GOUGECHECK Y
EDIT TOOLPATH LEADS SKIMDIST "3.0"
EDIT TOOLPATH LEADS PLUNGEDIST "1"
EDIT TOOLPATH LEADS INCREMENT_FROM_STOCK N
EDIT TOOLPATH LEADS RADIAL_CLEARANCE "0"
EDIT TOOLPATH LEADS PAGE FIRSTLEADIN
EDIT TOOLPATH LEADS SEPARATE_FIRSTLEADIN N
EDIT TOOLPATH LEADS PAGE LEADIN
EDIT TOOLPATH LEADS LEADIN HARC
EDIT TOOLPATH LEADS LEADIN ANGLE "10.0"
EDIT TOOLPATH LEADS LEADIN DISTANCE "0"
EDIT TOOLPATH LEADS LEADIN ANGLE "10"
EDIT TOOLPATH LEADS LEADIN LRAD "0.1"
EDIT TOOLPATH LEADS LEADIN2 NONE
EDIT TOOLPATH LEADS OVERLAPDIST "0"
EDIT TOOLPATH LEADS MOVESTARTPOINTS Y
EDIT TOOLPATH LEADS LEADSONSHORTLINKS Y
EDIT TOOLPATH LEADS LEADOUT COPY
EDIT TOOLPATH LEADS PAGE LEADSOUT
EDIT TOOLPATH LEADS PAGE LASTLEADOUT
EDIT TOOLPATH LEADS SEPARATE_LASTLEADOUT N
EDIT TOOLPATH LEADS PAGE LEADEXTENSIONS
EDIT TOOLPATH LEADS EXTIN NONE
EDIT TOOLPATH LEADS EXTOUT NONE
EDIT TOOLPATH LEADS PAGE LINK
EDIT TOOLPATH LEADS LINK THRESHOLD "10.0"
EDIT TOOLPATH LEADS LINK MOVE_DIR TOOLAXIS
EDIT TOOLPATH LEADS RETRACTDIST "0"
EDIT TOOLPATH LEADS APPROACHDIST "0"
EDIT TOOLPATH LEADS LINK ARCFIT N
EDIT TOOLPATH LEADS LINK INCR
EDIT TOOLPATH LEADS LONGLINK INCR
EDIT TOOLPATH LEADS SAFELINK INCR
LEADS ACCEPT
FORM TOOLAXIS
EDIT TOOLAXIS TYPE VERTICAL
DRAW TOOLAXIS_DEFINITION
UNDRAW TOOLAXIS_DEFINITION
EDIT COLLISIONAVOIDANCE SET OFF
TOOLAXIS ACCEPT
FORM FILTER
EDIT FILTER FACTOR "0.01"
EDIT USEMAXDIST ON
EDIT USEMAXDIST OFF
EDIT MESH TOLFACTOR 0.5
EDIT MESH USEMAXLENGTH OFF
FILTER ACCEPT
EDIT MODELCOLOUR RAISE SHADEDFORM
VIEW MODEL ; WIREFRAME ON EDIT MODEL ALL STYLE SOLID
UNSET MODLATERALS
UNSET MODLONGITS
QUIT EDIT TRIBOUNDARYANGLE 0
SET MODELSHADEDINSIDE
UNSET MODELSHADEDINSIDE
VIEW MODEL ; SHADE OUTLINES OFF
VIEW MODEL ; SHADETOL 0.003
VIEW MODEL ; UCANGLE 0
VIEW MODEL ; UCWANGLE 5.0
VIEW MODEL ; MINTOOLRAD 10
MODELCOLOUR ACCEPT
FORM COLOUR
COLOUR CLOSE
FORM OPTIONS
EDIT OPTIONS TREE OPTTOLERANCE
EDIT OPTIONS POLYTOL 0.001
EDIT OPTIONS CLOSETOL 0.1
EDIT IGESTOL 0.001
EDIT OPTIONS TREE OPTTOOLPATH
EDIT TPSELECT ; UNSELECTABLE CUTS
EDIT TPSELECT ; SELECTABLE CUTS
EDIT TPSELECT ; UNSELECTABLE CONNECTIONS
EDIT TPSELECT ; SELECTABLE CONNECTIONS
EDIT PREFERENCE AUTOSELECT NO
EDIT PREFERENCE AUTOSELECT YES
EDIT PREFERENCE CONTACTNORMALS NO
EDIT PREFERENCE AUTOSAVE NO
EDIT OPTIONS TOOLPATH AXISLENGTH 10
EDIT OPTIONS TOOLPATH NORMALLENGTH 10
EDIT OPTIONS TOOLPATH AXISLENGTH 10.0
EDIT PLUNGE_FACTOR 0.1
EDIT PREFERENCE TOOLFEED NO
EDIT OPTIONS TREE OPTVIEW
VIEW MINFPS 1
VIEW PREFFPS 20
VIEW ANIMATION TIMELIMIT 0.5
VIEW HITRAD 5
VIEW ARCTOL 0.005
ROTATE SPIN OFF
EDIT PREFERENCE INSTRUMENTONSELECTION YES
EDIT PREFERENCE USEMODELCOLOUR YES
EDIT OPTIONS TREE OPTIMPORT
EDIT MODEL SPLITSOLIDS NO
EDIT MODEL DEFER NO
EDIT OPTIONS TREE OPTTREENCPROGRAMS
EDIT NCPROGRAM PREFERENCES FILETYPE TAPEFILE
EDIT NCPROGRAM PREFERENCES MULTIPLE OFF
EDIT NCPROGRAM PREFERENCES OUTPUT WORKPLANE TOOLPATH
EDIT NCPROGRAM PREFERENCES OUTPUT WORKPLANE CREATION
EDIT NCPROGRAM PREFERENCES TAPEINFOFILE OFF
EDIT NCPROGRAM PREFERENCES OPT_EXTENSION "_LaserV22V33-Cu"
EDIT NCPROGRAM PREFERENCES ARCFIT 0.3
SETUPSHEETS AUTOBROWSE ON
OPTIONS ACCEPT
TOOLBAR SHADE RAISE\rVIEW MODEL ; SHADE RAINBOW
FORM COLLISION
EDIT COLLISION SPLIT_TOOLPATH N
EDIT COLLISION SPLIT_TOOLPATH Y
EDIT COLLISION MISS_OUTPUT N
EDIT COLLISION MISS_OUTPUT Y
EDIT COLLISION HIT_OUTPUT N
EDIT COLLISION HIT_OUTPUT Y
EDIT COLLISION REORDER YES
EDIT COLLISION REORDER NO
EDIT COLLISION SPLIT_SEGMENT N
EDIT COLLISION SPLIT_SEGMENT Y
EDIT COLLISION OVERLAP "0.1"
EDIT COLLISION MIN_LENGTH "0.02"
EDIT COLLISION HEAD_CLEARANCE "600"
EDIT COLLISION SHANK_CLEARANCE "0"
EDIT COLLISION HOLDER_CLEARANCE "0"
EDIT COLLISION DEPTH Y
EDIT COLLISION ADJUST_TOOL N
EDIT COLLISION APPLY
COLLISION ACCEPT
FORM DATUM
EDIT TOOLPATH START MODE AUTOMATIC
EDIT TOOLPATH START TYPE ABSOLUTE
EDIT TOOLPATH START MOVE_DIR TOOLAXIS
EDIT TOOLPATH START DISTANCE "5.0"
EDIT TOOLPATH START POSITION X "0"
EDIT TOOLPATH START POSITION Y "0"
EDIT TOOLPATH START POSITION Z "100"
EDIT DATUM PAGE END
EDIT TOOLPATH END MODE FIXED
EDIT DATUM PAGE START
EDIT TOOLPATH START MODE FIXED
EDIT TOOLPATH END MODE AUTOMATIC
EDIT TOOLPATH END TYPE ABSOLUTE
EDIT TOOLPATH END MOVE_DIR TOOLAXIS
EDIT TOOLPATH END DISTANCE "5"
EDIT TOOLPATH END MANUAL_AXIS N
EDIT TOOLPATH END POSITION X "0"
EDIT TOOLPATH END POSITION Y "0"
EDIT TOOLPATH END POSITION Z "100"
RESET TOOLPATH END
RESET TOOLPATH START_END
DATUM ACCEPT
DATUM ACCEPT
edit fstrip 0.02
EDIT COLOUR ViewBGTop 1.00000 1.00000 1.00000
EDIT COLOUR ViewBGBottom 0.00000 0.50196 0.25098
EDIT COLOUR ViewBGBottom 0.00000 0.43529 0.21569
COLOUR CLOSE
EDIT SORT SHORTEST
CURSOR TOOL DRAW
CURSOR CROSSHAIR DRAW
ole fileaction 'open' 'C:\dcam\pmill2\更改菜單\Cu\Cu菜單.bat'
FORM NCGLOBAL
EDIT NCPROGRAM PREFERENCES PROJECT ON EDIT NCPROGRAM ALL FILEMASK ''
NCGLOBAL ACCEPT
DIALOGS MESSAGE ON
DIALOGS ERROR ON
