查看: 2936|回复: 0
[PowerMILL] PM钻孔 怎么改变循环指令
发表于 2013-1-3 11:50:52 | 显示全部楼层 |阅读模式
machine fanuc15m
word order = ( OP N G6 G3 G1 G4 G7 G2 G5 )
word order = (+ X Y Z B C )
word order = (+ H M1 M2  MS T msg EM )
word order = (+ Q Q1 Z2 R2 ID F)
define word ID
  address letter = "O"
end define
define word TN
     address letter = "(TOOL TYPE: "
     address width  = 15
     field width    = 10
   end define
#35
   define word TD
     address letter = " (TOOL DIA.: "
     address width  = 12
     scale factor   = 2
   end define
#35
   define word TR
     address letter = "RADIUS "
     address width  = 7
   end define
   define word TLH
     address letter = "LENGTH ="
     address width  = 9
   end define
   define format ( TLH )
   metric formats
    decimal point              = true
   end define
#40
   define format ( TN TD TR )
     modal
     field width    = 8
     metric formats
     decimal places = 2
     trailing zeros = false
   end define
#45
  word order = ( + TN TD TR )
define word ID
end define
   define format (  X  Y  Z  )
      field width      = 8
      leading zeros = false
      decimal places = 2
    end define
define format ( F )
      field width   = 8
      trailing zeros = true
      decimal places = 1
    end define
define format all
  tape position = 1
end define
define format (T G1 G2 G3 M1 M2 )
  leading zeros = true
end define
define codes
  change tool = M1 6
  coolant on mist = M2 7
  coolant on flood = M2 8
  coolant off = M2 9
end define
message output = false
circle output = ( 0 1 1 0)
block order  = true
define block tape start
   "O0000"
    "(PROGRAM " ; ID JobName ;  " )"
G1 0 ; G2 49 ; G5 40
G1 91 ; G4 28 ; Z 0
G3 0 ;  G2 90 ; G5 54 ; X 0 ; Y 0
end define
define block tool change first
N  ; TD ToolRadius[ToolNum] ; TR TipRadius[ToolNum] ; TLH ToolLENGTH[ToolNum]  ;  " )"
N  ; "( PROGRAMMER: joel )"
M1 1
M1 6 ; T ToolNum
G6 90 ; G3 54 ; G1 0 ; X FromX ; Y FromY
G3 43 ; Z SafeZ ; H Toolnum
M2 8
S Toolspeed ; M1 3
end define
  M2 9
  M2 5
  G6 91 ; G4 28 ; Z 0 ; G6 =C ; G4 =C
  G6 90 ; X 0 ; Y 0 ; G6 =C
  M1 1
  M1 6 ; T ToolNum
  N  ; TD ToolRadius[ToolNum] ; TR TipRadius[ToolNum] ;  " )"
  G6 90 ; G3 54 ; G2 0 ; X FromX ; Y FromY
  G3 43 ; H Toolnum ; Z FromZ
  M2 8
  S Toolspeed ; M1 3
end define
define block move rapid
  G1 ; X ; Y ; Z
end define
define block move linear
  G1 ;  X ; Y ; Z ; F
end define
define block tape end
  Z FromZ
  M2 5
  M2 30
  G7 91 ; G5 28 ; Z 0
end define
end
