UF_FEATURE_SIGN sign = UF_NULLSIGN; double block_orig[3] = {0.0,0.0,0.0}; char *block_len[3] = {"1","2","3"}; tag_t blk_obj; UF_MODL_create_block1(sign, block_orig, block_len, &blk_obj); 用openc创建一个长方体,然后想用nxopenC++函数根据这个长方体的标示符blk_obj的到该长方体对象,希望大侠能够给出具体代码,谢谢
查看: 2057|回复: 0
[问题讨论] openc 和nxopenc++交互
发表于 2012-8-13 15:30:55 | 显示全部楼层 |阅读模式
  tag_t blk_obj;
