查看: 1015|回复: 0
[分享资料] 机床行业英汉对照表
发表于 2017-10-6 19:40:00 | 显示全部楼层 |阅读模式
机床行业英汉对照表:
3-Jaws indexing spacers三爪、分割工具头
  A.T.C.system加工中心机刀库
  Aluminum continuous melting & holding furnaces连续溶解保温炉
  Balancing equipment平衡设备
  Bayonet卡口
  Bearing fittings轴承配件
  Bearing processing equipment轴承加工机
  Bearings轴承
  Belt drive带传动
  Bending machines弯曲机
  Blades刀片
  Blades,saw锯片
  Bolts,screws & nuts螺栓,螺帽及螺丝
  Boring heads搪孔头
  Boring machines镗床
  Cable making tools造线机
  Casting,aluminium铸铝
  Casting,copper铸铜
  Casting,gray iron铸灰口铁
  Casting,malleable iron可锻铸铁
  Casting,other其他铸造
  Casting,steel铸钢
  Chain drive链传动
  Chain making tools造链机
  Chamfer machines倒角机
  Chucks夹盘
  Clamping/holding systems夹具/支持系统
  CNC bending presses电脑数控弯折机
  CNC boring machines电脑数控镗床
  CNC drilling machines电脑数控钻床
  CNC EDM wire-cutting machines电脑数控电火花线切削机
  CNC electric discharge machines电脑数控电火花机
  CNC engraving machines电脑数控雕刻机
  CNC grinding machines电脑数控磨床
  CNC lathes电脑数控车床
  CNC machine tool fittings电脑数控机床配件
  CNC milling machines电脑数控铣床
  CNC shearing machines电脑数控剪切机
  CNC toolings CNC刀杆
  CNC wire-cutting machines电脑数控线切削机
  Conveying chains输送链
  Coolers冷却机
  Coupling联轴器
  Crimping tools卷边工具
  Cutters刀具
  Cutting-off machines切断机
  Diamond cutters钻石刀具
  Dicing saws晶圆切割机
  Die casting dies压铸冲模
  Die casting machines压铸机
  Dies-progressive连续冲模
  Disposable toolholder bits舍弃式刀头
  Drawing machines拔丝机
  Drilling machines钻床
  Drilling machines bench钻床工作台
  Drilling machines,high-speed高速钻床
  Drilling machines,multi-spindle多轴钻床
  Drilling machines,radial摇臂钻床
  Drilling machines,vertical立式钻床
  drills钻头
  Electric discharge machines(EDM)电火花机
  Electric power tools电动刀具
  Engraving machines雕刻机
  Engraving machines,laser激光雕刻机
  Etching machines蚀刻机
  Finishing machines修整机
  Fixture夹具
  Forging dies锻模
  Forging,aluminium锻铝
  Forging,cold冷锻
  Forging,copper铜锻
  Forging,other其他锻造
  Forging,steel钢锻
  Foundry equipment铸造设备
  Gear cutting machines齿轮切削机
  Gears齿轮
