发表于 2014-11-27 19:35:36
显示全部楼层
这个后处理是什么机床上用的?我在UG10里用的时候报错
CAM_FILE: received CFI error -1 from CFI_delete_file(C:\Users\ONE\AppData\Local\Temp\ONE094CA89Bp3fk)
CAM_FILE: CFI error: -1: File not found
CAM_FILE: error -14 received from CFI_CLOSE of file temp_ju_.xl in directory D:\ju_conf\tempCAM_FILE: CFI error: -14: File not open
***TCL_ERROR***: Event Handler: F:\Program Files\Siemens\NX 10.0\mach\resource\postprocessor\ju_auto_post_sim.tcl, Event: MOM_start_of_path, Error: can't read "mom_group_name": no such variable
while executing
"if { $group_name($prog_count) != $mom_group_name } {
incr prog_count
set group_name($prog_count) $mom_group_name
(procedure "set_value_ju" line 24)
invoked from within
"set_value_ju"
(procedure "MOM_start_of_path" line 16)
invoked from within
"MOM_start_of_path"*** EXCEPTION: Error code 1770002 in line 505 of o:\ugnx100\ip14\src\camsmom\no\ind\mom_tcl_definitions.c at Thu Nov 27 19:29:07 2014 中国标准时间
+++ Error received in do_event. Event Handl |
